Extended cab and I've sprayed everything but the water hose in there and it's still on..
There is a loom of wires that connect the rear short door .. does any one know which wires i can disable to correst this problem ? I'll do it on both sides if I know which wires it is..can i just cut them or do they need to be tired together ?
IT is normally the latch that causes this, and use WD 40.. I would be very suprised if this doesnt work for you, I believe int he 2 years I have been on this forum, it has worked for everyone, but spray the latch.
