Ok guys i have a cross reference for yall. I have a 69 f100, but my transmission and transfer case came off of an 85 bronco. i've been told that my speedometer cable is supposed to thread into my transmission. then i was told, in the case of my tranny, my cable would thread into my transfer case. any of you guys know where it would thread in? cuz i can't tell. and drivetrain components ain't really my thing... also there are (what seem to be) 2 vacuum lines on the end of my transfer case. but they've been cut and i have no idea what they were for.
its on the tranfer cases left side kinda above the rear shaft yoke. Its at about 10 oclock. Any more questions just ask. And PS if your vacuum lines are cut the transmission wont work
yeah i know but then what could those 2 lines be for?
Rubber Lines? One should be on top of the transfer case and it should clip onto your 4x4 floor shifter underneath the truck and the end does not attach to anything its just an air line.
Assuming this is a 3 speed no overdrive C6 transmission
