Flathead transmission locked
Old Sep 20, 2009 | 01:39 PM
andy0812's Avatar
andy0812
Can't get my flathead out of reverse. I adjusted the clutch. With clutch in, truck will not roll. Any suggestions? Ran fine when I parked it. It has been sitting for several weeks Clutch pedal feels fine after adjustment.
Old Sep 20, 2009 | 02:36 PM
BlueOvalRage's Avatar
BlueOvalRage
Which transmission?
Old Sep 20, 2009 | 03:31 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Column shift or floor shift?
Old Sep 20, 2009 | 08:47 PM
reg1952's Avatar
reg1952
Maybe locked in two gears. 3 on the trees used to do this. If its on the column you could try moving the linkages up and down right at the bottom of the column while you rock the truck.Make sure there is someone there to apply brakes if it comes out of gear and starts to roll. If its a 4 speed I am sure others will help or have other ideas about the proplem.
Old Sep 21, 2009 | 08:14 AM
andy0812's Avatar
andy0812
Locked Transmission/Overheating
Thanks guys. Got it. I turned the key off. Pressed the starter button several time while trying to move the shift (on the column) That got it unlocked. Now for my favorite question and problem. My flathead runs hot and does overheat on occasion. (surprise) Anyone have suggestions? I have changed thermostats. I've drained the anti-freze and added just water and water pump lubricant. (That helped slightly.)I have an electric fan. Anything else? Just a note. When I bought it 6 years ago I drove it from Tennesee to NY without any overheating.
Old Sep 21, 2009 | 12:57 PM
andy0812's Avatar
andy0812
Thanks. Got it by trying to start it and moving column shift lever at the same time.
Old Sep 21, 2009 | 12:59 PM
andy0812's Avatar
andy0812
Got it. Tried starting it while moving column. Thanks
Old Sep 21, 2009 | 01:00 PM
andy0812's Avatar
andy0812
Got it. Tried to move shift on column while starting. Thanks
