Sponsored by: Real Truck
Automatic Windows
Old Sep 19, 2009 | 02:36 PM
ladderdawg's Avatar
ladderdawg
Automatic Windows
Need some help,
I have a 1999 F250 Superduty. Three of the four automatic windows will not roll down. I recently replaced the (4) switch cluster that is in the dirvers-side door panel thinking that the problem would be solved. No luck.
When I press the drivers-side window switch, I can hear a clicking under the dash, like maybe a relay. Should I be thinking about replacing the window motors?
Any help would be awesome.
Old Sep 19, 2009 | 08:20 PM
1975StroppeBaja's Avatar
1975StroppeBaja
Do the windows go down ok if you use the switch on the other doors? If the windows fail to go down from the driver's door switch and the switch on the other doors then I would suspect a wiring problem or the motor itself.
If you pop the door panel off you can use a voltmeter to look for voltage at the connector for the window motors. If there's voltage present and they still don't move, I'd say its the motor. If there's no voltage present, start working your way back to find the wiring problem.
I'm not sure about a relay that would be involved. Maybe someone else will chime in on that one.
Good luck!
Old Sep 19, 2009 | 08:34 PM
ladderdawg's Avatar
ladderdawg
Thanks for the info........
