Changing oil pump
Old Sep 19, 2009 | 08:18 AM
nickmobile67's Avatar
nickmobile67
Changing oil pump
I need to change an oil pump in a '93 F150 5.0 4wd. I know it's gonna be a big job. What's going to be involved in getting the oil pan down? Thanks!
Old Sep 19, 2009 | 08:48 AM
BKS72's Avatar
BKS72
Haha, I just posted about having to change mine As I was perusing the manual for an '89 F250 a minute ago it says to drain the coolant, pull the radiator, and pull the motor mount bolts.
Jack up the truck and put it on jack stands. Jack up the motor with block between the oil pan and jack so you don't ding the pan, and place a 1" block between the block and the motor mounts.
Let the motor down, then pull the pan bolts. Pull the oil pick up tube, lay it in the pan, and remove the pan. Might have to rotate the motor so the crank counterweights clear the pan.
That's what it says for my truck, probably similar to yours but somebody who knows for sure will probably post here in a bit.
I'm thinking if I'm diligent about it I can have the whole deal done in about 3 hours, not counting the time it'll take me to go get the pump and pan gasket.
Old Sep 19, 2009 | 09:13 AM
BKS72's Avatar
BKS72
Ooops- I was in the 6 cyl. section of the book. V8 is similar except they say to remove the upper intake and unbolt the exhaust. Sorry about that!
Old Sep 19, 2009 | 10:55 AM
Old93junk's Avatar
Old93junk
Get the one-piece rubber Motorcraft pan gasket, or you will be dropping the pan again because of leaks...............Yes, its a PITA job.
Old Sep 19, 2009 | 11:33 AM
quicklook2's Avatar
quicklook2
felpro blue one piece gasket is a good one to use.
do an advanced search in this forum and you will get a bunch of hits as this has been covered hundreds of times.
here are some tips:
radiator shroud needs to be removed.
trans mount bolts need to be removed and trans jacked up.
