Timing drops out
Old Sep 19, 2009 | 03:24 AM
Timba's Avatar
Timba
Smile Timing drops out
New longblock after having a full diagnostic the mechanic is stuck random missfires timing drops out at 50mph goes from 20 to zero changed timing sensor changed battery terminals all sensors seem to be working correctly also pings the mechanic cant figure out exactly what is causing this does anybody have a clue where to look truck is a f150 supercrew 4x4 5.4 triton 2000 its been on the scope for a week help
Old Sep 19, 2009 | 07:42 AM
glruff's Avatar
glruff
FTE Leadership Emeritus
Moving to tech forum.
Old Sep 19, 2009 | 08:28 AM
l-m tech's Avatar
l-m tech
did he install the tone ring backwards ,are the cams timed right ?
Old Sep 20, 2009 | 12:19 PM
LxMan1's Avatar
LxMan1
Make sure the MAF voltage is correct as well.
A lean condition will cause the pinging and will cause the timing to retard.
Old Sep 20, 2009 | 07:22 PM
Timba's Avatar
Timba
timing drops out pinging random missfires
the engine is a crate motor i think this problem was the cause of the old engine to blow a hole the size of a dime in piston #1 dont want the same to happen to new motor. truck is in a shop last i was told the flywheel could be cracked or put on in a differant position and now alternator is only putting out 10.2 volts sensors have been tested all working correctly .mechanic thought maf to now he doesnt think so help .truck shakes at low rpms
