esof vacuum solenoid test
Yes, I had the engine running. Did not just have the key on. Also in 4WD. When I switched back to 2WD the vacuum dropped to zero. I'll need to do a test, but I suspect the grounding for the two wires is controlled by the switch in the cab. That same switch controls the transaxil also. The transaxil does work for 4 X 4 as I currently use the manual method for 4 WD. Thank-you for your interest.
erikkloss
Jan 20, 2017 04:00 PM
dnkensinger
Aug 27, 2016 07:06 AM
Ford59galaxie
21
Feb 12, 2016 05:29 PM
FordandSkeeter
Jan 28, 2005 09:03 AM
