Hitch Insert "Anti-seize"
Old Sep 18, 2009 | 08:20 PM
eddiemoney's Avatar
eddiemoney
Might sound like kind of an odd request. I am looking to get a hitch insert to just leave in the back of my truck (protection from those idiots that like to get too damn close to me in parking lot). Obviously over time it will start rusting in there. I am looking for any ideas like a grease or lube or something that won't retain water (accelerate rust) and will prevent the insert from rusting to the factory bumper hitch over the next 10 years.
Vehicle : 2010 Expedition EL 4x4
Thanks for all your help
Old Sep 18, 2009 | 10:53 PM
mudmaker's Avatar
mudmaker
I wouldn't worry about it. They typically fit loose enough not to cause any issues.
Old Sep 19, 2009 | 04:01 AM
rebocardo's Avatar
rebocardo
You can pack blue wheel bearing grease in there around it. If you really wanted to, you could fit thin sheets of teflon in there instead.
If you have a grease gun get marine poly lube, it looks pink. When water hits it, it turns to a wax like material so it will not be washed away.
Old Sep 19, 2009 | 06:49 AM
eddiemoney's Avatar
eddiemoney
Thanks guys. I had one rust into an old car. .. only reason I am asking. Appreciate all your help.
Old Sep 19, 2009 | 07:47 AM
3800rs's Avatar
3800rs
these hitches rust instantly. Not to the point of being stuck, however i just painted the hitch and left the reciever in for like 2 days and rust already started to form. Maybe getting one of stainless steel will help
Old Sep 19, 2009 | 11:36 AM
Steina's Avatar
Steina
CO River Rat
Cut a strip from a milk carton and wrap it around the ball mount before inserting - clean and cheap.
Steve
Old Sep 22, 2009 | 12:03 AM
ClydeSDale's Avatar
ClydeSDale
Don't be a jerk. Just take it out and let the bumpers do their job and no one will get their shins "rung" or their vehicles damaged.
https://www.ford-trucks.com/forums/8...hitch-law.html
Old Sep 22, 2009 | 06:07 AM
eddiemoney's Avatar
eddiemoney
It isn't being a jerk. I see at least one set of bumpers kissing in my work parking lot everyday because of careless drivers. Why do I want a scratched up bumper because of morons.
I did just buy a stainless one, seems to work fine. . .looks good too.
Old Sep 22, 2009 | 02:28 PM
3800rs's Avatar
3800rs
nice, post up some pics
Old Sep 22, 2009 | 11:21 PM
jake00's Avatar
jake00
the one in my wife's durango rusted to the point where a bfh was needed. (was in there about 6 months.
I suppose you could use the same anti seize that they use on lugs
Old Sep 23, 2009 | 07:15 AM
jroehl's Avatar
jroehl
I had one rust in to the point that a BFH wouldn't even take it out. I ended up just strapping up to a stuck vehicle with it, then pulling the pin. Popped right out, but surprised my friend because I didn't forewarn him--he thought something had broken.
Jason
Old Sep 23, 2009 | 09:54 PM
rebocardo's Avatar
rebocardo
> I did just buy a stainless one, seems to work fine. . .looks good too.[/quote]
Put a lock on it, masterlock makes a nice combo kit for the receiver and trailer. On the lock itself if you are planning on leaving it there forever, I would fill the pin part and key part with lube if you live in a salted road state.
Old Sep 25, 2009 | 09:58 AM
slickrock01's Avatar
slickrock01
wheel bearing grease, same as we put on the 5th wheel plates on tractor trailers, WD hitches, etc.
slide the hitch out once a year and slap some wheel bearing grease on it and put it back in. Done.
Old Sep 25, 2009 | 10:52 AM
stormyrider's Avatar
stormyrider
You mitght try beeswax, cheapest source is the old toilet stool seal wax seals. Take the adaptor out and heat it with a propane torch and then slide the seal along it to get a good coating as it melts. after it has cooled reinstall. I left mine in a couple of months and ended up using my farm tractor to tug it out, it was not lubed in anyway.
Old Sep 29, 2009 | 08:13 PM
Toyman's Avatar
Toyman
With people freaking out about the "new" law of leaving the hitch in. why don't you look into one of the step inserts (looks like a little nerf bar), lock the in and use what ever type of water resistant grease you want. just take it out and re-grease from time to time.
mofoco1
15
Mar 7, 2014 05:05 PM
milsuper
6.7L Power Stroke Diesel
Mar 19, 2012 11:35 AM
FloridaFordGirl
Florida Chapter
Oct 24, 2011 03:10 PM
OldHarley
Apr 2, 2010 04:43 AM
banddr2
Jan 23, 2009 08:40 AM
