getting pretty low on my BFG ATs wanting to get new tires soon. just wondering if I will be able to run nitto mud grapplers 37x13.5xr17 on an 04 with a 6'' lift? will they rub on the springs or what?
thanks guys
orng1: i know the tires will clear the body/fenders/bumpers. my question is i am going to rub on the front leaf springs?
I would determine the amount of clearance you currently have with the 35/12.50R17 tires. If you have more than 1/2" clearance from the front leave springs at full turn, then you should be fine with the 37/13.50R17 tires. Why? Because the new tires are only 1/2" wider on each side of the wheel as your current tires. Does this make sense?
