Aerostar Ford Aerostar
lock steering column intermittent problem
Old Sep 17, 2009 | 05:24 PM
FES's Avatar
FES
1992 Aerostar w/135,000 miles. Usually I 'cannot' rotate my ignition key into 'lock' position, and remove the key, but sometimes, the key will rotate to 'lock' and I can remove the key. Do you think it might help if I remove the unit from the column, spray some type of lubricant inside and reinstall ? Any suggestions as to what type of lubricant ? I just replaced the iginition tumbler switch (again) my 3rd one, last night and it worked like it should a few times with the engine off. Did a test drive, got back home, put shift lever into park and for I don't know why, it would not rotate into lock position. Did a second test drive, got home and I was able to rotate the key into lock position without any problem and remove the key. Sure hope someone might have the answer because I have no idea. Thanks for your help.
Old Sep 22, 2009 | 08:55 AM
FES's Avatar
FES
Well, talk about feeling stupid...I figured out my problem and I did not need a new ignition switch. The position of the steering wheel determines if the ignition key can be rotated to the 'lock' position and be able to remove the key. Sorry about taking your time reading my previous post but just wanted everyone to know my problem is solved (as far as I know-I think).
bismic
Mar 9, 2022 09:20 AM
bismic
Aug 10, 2015 10:35 AM
RANGER589
18
Jun 3, 2011 10:03 AM
charon61285
Sep 20, 2009 11:32 PM
oldusedbear
Modular V10 (6.8l)
Jul 23, 2008 11:43 AM
