140 amp
Old Sep 16, 2009 | 11:08 PM
anderson sc's Avatar
anderson sc
140 amp
Got a 140 amp. alternator by powermaster has a internal regulator. My understanding is that all I have to do is hook up the lead line to battery? If I want to have the indicator light to work need to plug in the green wire? I dont know about my 68 truck, but when you first turn on key switch should the indicator light come on? If so mine don't. But seemed to remember seeing the light go on (just a little)once when the battery was getting very low. I plan to install a volt meter anyway. Up grading do to installing new 60-55 watt lights from Summit and for the trailer lights. I also ordered light wire harness from LMC. Thanks for any in put!
