Sponsored by: Real Truck
F-450 Engine Oil Temp Problem
Old Sep 16, 2009 | 10:42 AM
taxmansteele's Avatar
taxmansteele
F-450 diesel dually 4.88 rear axle ratio, GCWR 33,000; towing fifth wheel Teton 15-16,000 pounds; when towing, coolant temp needle will go to "H", message says "Reduced Engine Power"; if I was going 60 mph, speed will drop to about 50 mph; after short time (even continiung down road), message will disappear and needle drop back to normal range; I might go another 100 miles or so before it might happen again; when opening hood, coolant does not appear to be low, nor is it bubbling over from overheating; NEXT TWIST: Owner previous to me installed an EDGE Performance product on this truck; according to EDGE computer screen, above happens whenever engine oil temp exceeds 260 degrees; when temp drops back below 260 degrees, that is when message disappears and needle returns to normal; EDGE computer is set to only give an alert when engine oil temp exceeds 290 degrees; on next trip, I will remove EDGE product, restore Ford stock PCM settings and see if problem occurs again; any comments on what may be going on greatly appreciated
