wastegate linkage adjustment
Sep 15, 2009 | 11:36 AM
witch way do i ajust the linkage for more boost ?? could that be my issue??
Sep 15, 2009 | 11:50 AM
You shorten the actuator rod to put more holding pressure on the wastegate.
Sep 15, 2009 | 11:56 AM
holding
thank you for the responce. holding preasure creates more boost
Sep 15, 2009 | 12:15 PM
Quote:
Originally Posted by
wuttrd
Yes, the longer the WG stays closed the more boost you will be able to build.
Sep 15, 2009 | 12:28 PM
boost
thanks i will try that next
03 ,
1999 ,
250 ,
73 ,
99 ,
adjust ,
adjustment ,
automatic ,
diesel ,
f250 ,
ford ,
linkage ,
powerstroke ,
rods ,
wastegate
