Egt?
Old Sep 14, 2009 | 10:22 PM
roushcm's Avatar
roushcm
Egt?
I was woundering about my egt temp? When driving to work on flat ground and small hills it is between 550 and 800. When i pass a car or truck i can see as high as 1400! I have a edge tuner on the tow setting with a 5in mbrp pipe installed. on the stock setting it can go as high as 1300! This is my first PSD and i dont want to be paranoide to get on it. You guys also helped my figure out my boost problems so i thought i would ask you guys about this. Thanks for any help.
Old Sep 14, 2009 | 10:28 PM
Layson's Avatar
Layson
You are fine in short bursts to go past 1200... but it also sounds like you may have a boost leak or a up-pipe leak... I am not sure if the edge just runs a little hotter too...
Old Sep 14, 2009 | 10:52 PM
roushcm's Avatar
roushcm
I can run up to 25psi boost on my autometer gauge, but the edge reads 11 so im replaceing my map sensor tomarrow.
Old Sep 14, 2009 | 11:11 PM
Layson's Avatar
Layson
do you have a boost fooler? Are you setting a SES light at all?
Old Sep 15, 2009 | 06:37 AM
roushcm's Avatar
roushcm
No i do not have a boost fooler yet. and i also dont see a ses.
