Fuel coming from glowplug?
Old Sep 14, 2009 | 10:00 PM
Steelheader87's Avatar
Steelheader87
I have fuel bubbling out of where the glowplug threads in. The plug is tight, but fuel is coming from the plug. What does this mean? Do I have an injector issue? Thanks again for all the responses and help.
Old Sep 14, 2009 | 11:33 PM
Dave Sponaugle's Avatar
Dave Sponaugle
You are leaking compression around the glow plug.
The fuel is probably from the return lines.
Old Sep 15, 2009 | 09:19 PM
Steelheader87
Not to sound like an idiot, because I simply don't know, but aside from focusing on the return line, is there anything else that I need to be looking for? A buddy told me he thought I may need a new injector and if I was going to change one, I should change them all. 87 crew cab with 176,000. What are your thoughts?
Old Sep 15, 2009 | 09:27 PM
Kleenax's Avatar
Kleenax
I had the exact same problem, and I took out the glow plugs, cleaned the threads and put some anti-sieze (yes I know I wasn't supposed to) on them and torqued em down good. Problem went away. I swear it was fuel bubbling up and not just compression; cleaned em off twice to see it good.
Old Sep 15, 2009 | 11:19 PM
Dave Sponaugle
I always use never sieze on my glow plugs when I install them.
Injectors to for that matter.
