you know i'm not one to just try something with out just hard proof that it works well i'm here to tell you that as of to day and I don't know how long it will last but hot shot secret fixed my bad injector I was getting a code po278 and my truck was running like crap well as of to day 400 miles after adding hot shot truck is running just fine crank time is shorter no shutter no skip no black smoke out the tail pipe the stuff worked for me and no I am not tring to sale there product just saing it worked for me and saved me a bunch of money
Glad it worked for you.. If you had a known problem, I guess it was worth a try? I'm curious to see what happens after some more miles.. Please keep posting your experience..
i was throwing an injector code, switched to full syn. oil and poured in some TCW-3 two stroke oil. no code and runs nice and smooth.
I have 80,000 on my X and have never thrown an injector code. However, I have used Royal Purple 20W-50 synthetic motor oil from day one and change it every 7,500 to 10,000 miles. Every 5,000 miles or there abouts I put in 2 quarts of RP TCW-3 synthetic 2 cycle oil in the fuel tank. Never had a problem with fuel injectors.
Also, I use Hot Shot Secret in my motor oil and there cetane booster for the fuel.
DSMMH
Reason: add more info
you guys are putting two cycle oil into your fuel tank? does it smoke?
No smoke, been using it for 2 years now and what I notice most about it is when the temp. goes down 5-15 deg. the truck starts right up with no shake for the first few seconds.
Everytime I get fuel I add the 2 stroke oil. I buy it in gallon jugs and I fill a 16 oz. plastic bottle which is kept in the lower door compartment of my rear door of the super cab. I wait for the fuel gauge to get down to half (29 gal. tank) then when I add fuel the whole pint bottle gets dumped in, so it comes out to 1 oz. per gallon. I use the empty gallon jugs to store my engine waste oil.
