Sponsored by: Real Truck
Power window down and rain coming
Old Sep 14, 2009 | 11:16 AM
Kurtzz's Avatar
Kurtzz
Any way to manually raise the passenger power window? It rolled down and will not go back up, rain is coming..
99 5.4 250SDSC 4X4
Thanks in advance
Kurtzz
Old Sep 14, 2009 | 11:58 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Not without removing the inside door panel..... Easier to move it to cover - or cover IT.
Old Sep 14, 2009 | 12:09 PM
1Aauto's Avatar
1Aauto
Former Vendor
You would have to remove the door panel and push it up by hand. Did the regulator break on you?
If it keeps sliding down you can put a piece of wood on something under it to hold it in place until you can fix it.
Old Sep 14, 2009 | 08:43 PM
Kurtzz's Avatar
Kurtzz
Thanks for the tips. I was able to spray a little FI/Carb cleaner in the switch and got it working again. I did remove the door card, two screws and pull up (easiest door card to remove I have ever seen) but was unable to lift the window, that was when I broke out the carb cleaner on the switch. Make a long story shot, which I never do, a big thanks FTE for the knowledge on how to remove the door card.
1ATony I do not see the switches listed on your website for the 99 F250 SDSC 4X4 and the ones you show do not match in appearance my switches...wish they did you have some smooookin prices. I have your site saved in my Fav's now. I am a new to the Ford truck owner experience, I have driven high perf sports cars my whole life but a friend made me an offer on his single owner F250SD with REAL low miles so I had to pick it up. It is a little overkill to tow my jon boat but everybody needs a truck!
Thanks again!
Kurtzz
Old Sep 14, 2009 | 08:59 PM
EXv10's Avatar
EXv10
Be carefull using your window washer with the driver window down. I have ruined switches in a least 2 cars that way. The spray does go right to my switches on the EX if it is open.
Old Sep 15, 2009 | 11:53 AM
1Aauto's Avatar
1Aauto
Former Vendor
Thanks again!
Kurtzz
You're welcome. I checked for you and as of right now we do not have a source for your application for those switches. I let the purchasing dept. know too.
T
