Need help finding this fuel tank part:
Old Sep 13, 2009 | 01:18 PM
tseekins's Avatar
tseekins
Veteran: Coast Guard
1988 F-150 4x4 19.0 gallon midship tank.
I just replaced the fuel pump last weekend and now the tank is leaking form the top. I crawled under the truck and determined that gas is coming out of the seal / grommet on the top of the tank adjacent to the pump. I think I damaged this piece when I removed the tube from the tank.
The Haynes manual calls it the "vapor tube emssions control valve"? I can't find this seal / grommet anywhere on line or around town. I may have to call the dealer tomorrow.
Any ideas?
Thanks,
Tim
Old Sep 13, 2009 | 02:17 PM
Lazy K's Avatar
Lazy K
Have you tried RockAuto or partsguyed.com at y2kparts?
Old Sep 13, 2009 | 03:07 PM
tseekins's Avatar
tseekins
I tried these guys and any and all online parts suppliers and they list the valve but not the rubber grommet that the valve sits in.
I wrapped some tape around the grommet, re-installed the valve and went for a ride and I couldn't smell gas or see any leaks......for now. That bandage may buy a couple of days until I can get to the dealer.
The grommet has a part number on it so Ford must have it.
Tim
Old Sep 14, 2009 | 05:07 PM
tseekins's Avatar
tseekins
Found the part
The vent tube seal on the fuel tank is a dealer only item.
Just in case anyone needs this part the number is: F6TZ-9B076-AA
$6.29 + tax.
Tim
Old Sep 14, 2009 | 05:59 PM
jr32560's Avatar
jr32560
oh the small vent tube housing that pops into the tank- I get mine from a junk yard
great ya found it and posted part #s and all good looking out!
Old Sep 14, 2009 | 06:28 PM
Jermafenser's Avatar
Jermafenser
Tim
That's actually an ID number, not the actual part number. Is the part number on your receipt?
Old Sep 14, 2009 | 07:16 PM
tseekins's Avatar
tseekins
I was going to the junkyard but I figured that if mine was deteriorated, another old one may not be in much better shape.
That's the number that's listed on the reciept and the package.
Tim
Old Sep 15, 2009 | 10:31 AM
Ohio Ford Farm's Avatar
Ohio Ford Farm
http://broncograveyard.com/bronco/i-...valve_seal.htm
$6.00 at Jeff's Bronco Graveyard.
Old Sep 28, 2009 | 09:56 PM
axman_F250's Avatar
axman_F250
$6.29 + tax.
Tim
Thanks for the info. I'm having a similar challenge.
If I may ask - how did you get the plastic valve out without breaking it?
Thanks,
ax
Old Sep 29, 2009 | 05:29 AM
tseekins's Avatar
tseekins
Thanks,
ax
It's seated like a PCV valve in a similar type of rubber grommet. It simply pulls out. The troubel with mine was the grommet was so deteriorated that when I pulled out the valve, the grommet ripped.
Tim
superman64011
32
Feb 13, 2022 10:33 PM
Ford59galaxie
Dec 15, 2015 05:08 AM
sloppyslim16
19
May 15, 2015 05:46 PM
piratius
Jun 16, 2010 11:23 PM
FOSE88
Oct 5, 2006 10:55 AM
