Break-in Oils
Old Sep 13, 2009 | 12:53 PM
mpuvdd's Avatar
mpuvdd
Question Break-in Oils
I've just finished a 20 min. break-in at 2000 rpm using Joe Gibbs Break-In Oil. This is in a freshly rebuilt 429 by the way. It has a flat tappet cam with old-style rockers. What do you recommend for the next stage of oils? I do want an oil high in zddp, right?
Old Sep 14, 2009 | 08:12 AM
Poison Oil Racing's Avatar
Poison Oil Racing
valvoline racing oil has high zddp content. I use Comp Cams break in lube added to the Valvoline racing oil for break in, then switch to just Valvoline racing oil after that.
Old Sep 14, 2009 | 10:39 PM
mpuvdd's Avatar
mpuvdd
My engine builder recommended Joe Gibbs Hotrod oil, Mobil 1 15w50, and/or Amsoil 20w50. I'd take his word any day. However, I think these are synthetic (not to mention they start at $8.50 a qrt.), which, I'd rather use mineral based. Anyway, I think I'm going to look into that Valvoline oil (thanks POR).
Old Sep 15, 2009 | 05:42 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Kendall GT-1 (the green oil) is now made by Brad Penn. http://www.bradpennracing.com/
Good stuff for break in's.
You might look at Shell Rotella T -after break in- as well.
It's marketed as a diesel oil, but is higher in ZDDP than Spark Ignition (SI) rated oils.
I saw the 15W40 in Walmart last week for under $12 a gallon.
FWIW, I don't know what kind of spring pressure you're running and have no experience with flat tappets in a 460, but it works well in my truck, bikes & 347" solid roller.
Old Sep 20, 2009 | 01:30 PM
OrangeJuice's Avatar
OrangeJuice
I use Brad Penn (The Green Oil) for break-in for it's high level of zddp. I continue to run the same oil in 15W40 in my big block 402 since it provides me with good oil pressure. Brad Penn oil was recomended by a local race shop in my area.
OJ
