Sponsored by: Real Truck
Ball joint nut size?
Old Sep 13, 2009 | 10:05 AM
wanabe2's Avatar
wanabe2
Im getting ready to change my ball joints on my 03 FX4 250 and was wondering what size sockets I need to change the Ball joints? I have been told 28mm for the top and 34 mm for the bottom? Someone also told me the bottom was a 32mm? I looked over at snap on and they dont even sell a 1/2" drive 28 mm! So where can I order them? Do I need impact sockets? Thanks!
Old Sep 13, 2009 | 11:16 AM
pipefitter73's Avatar
pipefitter73
wanabe try this linky on this forum. I am a total noob to this scene, but this put this tutorial together. It is excellent and list's all sizes and tools you will need. You can't go wrong with this play by play. He did a great job. Take a look and read, good info.
https://www.ford-trucks.com/forums/3...ll-joints.html
and this
http://www.superdutypsd.com/ball_joint_article.php
Old Sep 13, 2009 | 11:29 AM
1975StroppeBaja's Avatar
1975StroppeBaja
When I did mine, for the original upper nut I used 1-1/8" and the lower I used 33mm.
I put Moog's in and both upper & lowers used a 33mm nut.
Good luck!
Old Sep 13, 2009 | 02:26 PM
wanabe2's Avatar
wanabe2
So they are not metric? Im confused....
Old Sep 13, 2009 | 02:27 PM
wanabe2's Avatar
wanabe2
Forgot to say, im using ford balljoints, with the grease zerks
Old Sep 13, 2009 | 02:32 PM
cole60's Avatar
cole60
For some reason 1 1/4 pops in to my head for the top one but I am not sure right off hand. If you have the new ball joints take the nut and get the right sockets. I dose not need to be impact socket. I used my breaker bar and snap on batt. gun to do the hole job. There should be a torque setting for the nuts too.
it is a easy job too...
mean351stang
Aug 10, 2023 06:04 PM
c3racer2000
1978 - 1996 Big Bronco
Mar 7, 2022 04:32 AM
nvrsadi
May 17, 2016 05:19 PM
74Styleside
Jun 3, 2012 06:22 AM
Swampwater
1997 - 2003 F150
Apr 11, 2003 05:55 PM
