Clunk noise
Old Sep 11, 2009 | 07:09 PM
crazymut's Avatar
crazymut
Clunk noise
When I am turning my steering wheel full deflection either way, usually only going slow or stopped, I get a clunk noise. I can feel it in the wheel. I have changed my wheel bearings recently and my sway bar bushings and link arms. I am wondering if any bushings in the steering could be causing this.
Old Sep 11, 2009 | 08:46 PM
Tenn01PSD350's Avatar
Tenn01PSD350
I get the same thing. My hub bearings and ball joints are good as is the steering and tracking when I drive so I don't care, but subscribing anyway. I am thinking it is in the steering linkage somewhere.
Old Sep 11, 2009 | 09:29 PM
Billyclub's Avatar
Billyclub
I had the same problem last month but only really happened when I stepped on the brakes. Took it to my mechanic and we went through the front end, he was kind enough to let me work on the truck with him so I could do the work in the future myself. Anyway, we replaced the spindle bearing and outer shaft due to a groove in the shaft which allowed the U joint to contact the zirk fitting on the hub to hit the U joint as it spun by. also did the U joints, one of the joints was frozen. Amazing how tight things need to be.
