Sponsored by: Real Truck
brake vibration
Old Sep 11, 2009 | 10:02 AM
raymondtiger's Avatar
raymondtiger
brake vibration
I have a 2001 f250 v10 and I changed the rear pads month ago had some vibration so raplaced one rotor and turned the other, I still have some vibration when braking, the severity changes sometimes it is bad sometimes don't even notice it, any suggestions?
Thanks
Tiger
Old Sep 11, 2009 | 10:53 AM
jsparrow's Avatar
jsparrow
Usually you should replace or turn them both instead of one of each. Sometimes....and this is a very BIG sometimes....rotors are produced with "hard spots". It happens when the metals in the rotors aren't quite blended fully so you get a spot on the contact surface of the rotor that doesn't act the same when the pad meets it. It causes a pulsing sort of stop. If the rotor is new sometimes it can take a few hundred miles for it to smooth out. Just give it time to burnish and don't stop too hard for awhile. Most likely that's not the problem but it could be. Just a thought.
Old Sep 11, 2009 | 11:25 AM
QckSlvr's Avatar
QckSlvr
we had some pulsing issues after 55k miles so we did an entire rotor/pad swap in the front end and it cured the problem.
Jamie
battmanf16
22
Mar 11, 2020 11:36 PM
blackbeautyf250
Apr 4, 2013 05:22 PM
phillips91
Aug 25, 2009 07:20 AM
f1barry
Nov 21, 2008 12:58 PM
greenterror
Mar 20, 2007 08:30 AM
