How did this happen?
Old Sep 11, 2009 | 09:24 AM
Mr. Obvious's Avatar
Mr. Obvious
Went to change the transfer case fluid today and drained out 3 quarts. Filled it up with 2 and it was just coming out the filler hole. Manual also says 2 quart capacity.
It was a 1 owner with 96000 miles when I bought it (always dealer serviced). No way the previous owner touched it. Did it come this way from the factory? Hard for even a dealer to get 3 quarts in there when it starts running back out at 2 quarts.
Old Sep 11, 2009 | 09:28 AM
Omahastro1's Avatar
Omahastro1
Could the seals between the trans and TC be bad and fluid is coming from the trans?
Old Sep 11, 2009 | 10:51 AM
alloro's Avatar
alloro
That's exactly what I was thinking.
Old Sep 11, 2009 | 12:04 PM
deddy's Avatar
deddy
Same thing happened for me.
Is it possible that it was filled with more than 2 quarts from the factory?
Old Sep 11, 2009 | 12:31 PM
Big Greenie's Avatar
Big Greenie
Temporarily Deactivated
It is possible they were overfilled by the factory, anything is possible. It almost seems more likely than transference between the trans and t-case. The transmission has an output shaft seal, and the t-case has a input shaft seal. Both would have to fail in order for the fluid to move from one place to the other. Your trans would also show a qt low if this had happened. If the trans seal was bad it is more likely that it would have leaked out between the two components onto the ground than forced its way inside the t-case.
Old Sep 11, 2009 | 09:38 PM
Mr. Obvious
Funny thing when I bought the truck last fall it was a little low on tranny fluid (1/2 quart) so I added some. Then this spring it was a little low again. Don't see a leak anywhere so you may be right.
Old Sep 12, 2009 | 12:35 PM
alloro's Avatar
alloro
Well that's Obvious Mr.
max3860
Oct 14, 2019 09:49 PM
EpicCowlick
Aug 12, 2016 09:07 PM
petro1
6.7L Power Stroke Diesel
Aug 24, 2011 05:17 PM
vronp
Nov 15, 2010 07:56 AM
tonyford
Escape & Escape Hybrid
Jan 4, 2006 12:25 PM
