77 axles
Old Sep 10, 2009 | 11:06 PM
65390's Avatar
65390
77 axles
i have a 77 f 150 4x4 ,,i wanted to know if the front axles will fit my 77 4x4 from a 79 bronco?..i know they take the same axle joint , but is the axle the same?...not the housing , but the axle its self..will they swap over from the bronco to my 77 f 150....just asking cuzz i have a 79 bronco for parts and my 77 needs an axle joint and just figured i would just swap the axle ....and one more...i know the steering colum is different from my 77 to the 79 bronco ..is there anyway to make the 79 colum fit my 77 without changing the whole wire harness just becuase of the turn signal swith and wire's?...the bronco colum shift's real smooth and works great , but the wire and wire connector are different from the 79 bronco to my 77 f 150 ..even the way the turn signal mounts in the colum is completely different ..thanks
