carb vent?
Old Sep 10, 2009 | 08:19 PM
lance65's Avatar
lance65
carb vent?
I have a 1977 F250 w/460. The carb is a motorcraft 4350 from a '77 full size car w/460(D7VE SA is the tag #). My question is, on top of the carb is a bowl vent tube. Do I need this to pass emissions or just plug it? If I do need it,where do I hook it up at? Thanks
ALSO,the air cleaner vacuum,is it manifold vacuum (for the air cleaner thermostat?)
-Lance
Old Sep 10, 2009 | 10:04 PM
montana_highboy's Avatar
montana_highboy
If you have a visual inspection in your county you'll need it, it plugs into your evaporative canister (if so equipped).
