really dumb question
Old Sep 10, 2009 | 06:57 PM
cowmilker08's Avatar
cowmilker08
Question really dumb question
I want to order my 203* thermostat from dieselsite this weekend (depending how i fare at the neighbor texas holdem tourney). Anyway I wanted to make sure that it only takes one thermostat and not two like some things.
Old Sep 10, 2009 | 07:03 PM
helifixer's Avatar
helifixer
just one .
Old Sep 11, 2009 | 09:06 AM
MisterG's Avatar
MisterG
You might as well spend a few extra bucks and get the water neck from dieselsite also.
Old Sep 11, 2009 | 12:53 PM
cowmilker08
What's the point of their water neck?
Old Sep 11, 2009 | 01:53 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
The old one tends to deform in the base and will cause leaks.
Old Sep 11, 2009 | 02:08 PM
TheTowingCowboy's Avatar
TheTowingCowboy
Get new neck, best thing you can do.... BELIEVE ME!
Old Sep 11, 2009 | 02:21 PM
MisterG's Avatar
MisterG
You might get lucky and be able to use the old one with out any leaks, but for only 32 dollars, your better off just replacing it and only having to deal with it just once. And when you take off the old one, chances are you will find corrosion on the inside and you don't want that in your cooling system.
