brake contoller
Old Sep 10, 2009 | 11:32 AM
mollikate's Avatar
mollikate
brake contoller
on one trailer of many i haul, when i hook up pigtail with flashers on my brake controller light flashes, but only then
any ideas as to why
THANKS GUYS,
Michael
Old Sep 10, 2009 | 12:22 PM
stormyrider's Avatar
stormyrider
Your turn signals, brake lights and four way flashers are powering the same filiament inside the bulb. Tail lights use a seperate filiament, therfore when the fourways are on the power output LED on your brake controller is seeing power on that wire and indicating it.
Old Sep 10, 2009 | 01:30 PM
mollikate's Avatar
mollikate
why only that trailer. others using leds dont do it
Old Sep 11, 2009 | 09:11 PM
TexasRebel's Avatar
TexasRebel
does it flash with the flashers?
how many pins on the connection? 4, 7?
Old Sep 12, 2009 | 08:37 AM
stormyrider
Are the trailers ground routed through the connector or are some routed through the hitch? Ground wire through the connector is best to prevent odd light shows or lites that are not working properly.
Old Sep 25, 2009 | 09:52 AM
slickrock01's Avatar
slickrock01
did you get this straightened out?
I saw a trailer the other day, utility type, and everytime his flashers went on the brakes locked on the trailer, quite a show going up a good incline!
rest of his lights looked ok, brake, turns, but everytime the 4 ways went on;
flash--squeel--flash-- squeel---flash--squeel, finally he pulled over
