windows
Old Sep 9, 2009 | 06:26 PM
bearhugger's Avatar
bearhugger
windows
95 f350 cc 5 speed 3:55.
anyone out there have a diagram of the window switch , motor and
wiring for the windows.
Thanks Jim
Old Sep 9, 2009 | 06:57 PM
Cuda_jim's Avatar
Cuda_jim
Here ya go:
Old Sep 9, 2009 | 07:35 PM
FARM69's Avatar
FARM69
Good wiring diagram Cuda... Saved it to my HD. Tried to rep ya but I have to spread it around...
Old Sep 9, 2009 | 07:43 PM
bearhugger's Avatar
bearhugger
window
Thanks a lot Cuda,just what i needed.
Jim
Old Sep 10, 2009 | 10:17 AM
Brown Falcon's Avatar
Brown Falcon
Good diagram... need to get my rear windows working...
Old Sep 10, 2009 | 06:19 PM
Hussler's Avatar
Hussler
Hint, went through this last year. If you have the CC all power to PS front and DS/PS rear goes through the DS (master switch) first. So if that is flaky, like mine the others won't work. I guess it makes sense because that is the door opened most often and gets wet from the rain.
If you tear that master switch apart it has little tiny, tiny, tiny contacts that are impossible to repair or clean, I tried. Mine were all green from corrosion. Long story short I searched the internet forever and the only replacement was from a guy in California that pulled one from a junk yard and wanted $44 with no warranty.
Did the unthinkable and called local Ford dealer and got a NEW replacement DS master and I think it was $57.
in my case ...
Old Sep 10, 2009 | 06:31 PM
Brown Falcon
in my case ...
Thanks for that info Hussler... havn't even looked into that switch yet. The DS front switch will operate the two front windows on mine but not the rear. They don't work at all...
Old Sep 10, 2009 | 07:12 PM
Cuda_jim's Avatar
Cuda_jim
I agree with hussler, the rears are powered through the front switch, even shows it in the schematics above.
Since the rears are working I'll bet the DS switch is the culprit.
cujo8
Jul 11, 2006 03:32 PM
JRL
Oct 14, 2005 06:00 PM
NRATC
Jul 1, 2005 06:43 AM
bitoman
Sep 20, 2003 04:58 PM
