Ranger with fusion applied
on
Finally got off the puter long enough to start applying the Fusion plastic paint to the Ranger
I decided to tape off the painted services. I'll let you decide how I did with this task. Took my time and used the blue painters tape. Regular masking tape is not recommended since it didn't want to stick to the painted services.
Used a razor knife to slowly cut around the plastic, leaving the tape on the painted surfaces.
Use this to prep the surface before painting.
It appears to me that the Ranger will use 3 spray cans of Fusion to complete the job, applying 3 coats.
This is what I have completed so far, I have before and after pics for your viewing pleasure.
Running boards before,,,
After,,,
Driver front flare before...
After,,,,
Driver side rear flare before,,,,
Driver side rear flare after,,,
The Driver side complete,,,
After,,,
After,,,,
on
