Modular V10 (6.8l)
High oil temp?
Old Sep 8, 2009 | 09:37 AM
siearly's Avatar
siearly
High oil temp?
Posted this in the SD forum but it might be better placed here.
I'm putting gauges in my recently-aquired 2001 F250 V10. I installed a ScanGauge
http://www.scangauge.com/
but also wanted oil temp and pressure so I installed analog Sunpro temp and pressure. They are electric and I mounted the senders by the oil filter using an adaptor from GlowShift
http://www.glowshiftdirect.com/
The problem is, as the engine warms up, the oil temp runs right up to about 260. I pulled the gauge and sender and bench tested it to make sure it was not defective. It does read about 15 degrees too high but, correcting for that, I still have 260 indicated. The coolant and cylinder head temps stay at 190.
I'm used to oil temps of about 180 so 260 seems too high to me. I also don't see how it can run that high when the factory oil cooling lines are taken from the same location and cooled by the coolant (which is running 190).
Any thoughts? <!-- / message --><!-- BEGIN TEMPLATE: ad_showthread_firstpost_sig --><!-- END TEMPLATE: ad_showthread_firstpost_sig -->
Old Sep 9, 2009 | 07:17 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Weird. Do you have one of those point-and-shoot infra-red thermometers?
When the gauge says it's that high, maybe you could check the temp of the oil filter?
Old Sep 9, 2009 | 08:17 AM
siearly's Avatar
siearly
That's a good thought. I don't have an infra-red thermometer but this might be a reason to buy one.
I know some others have installed the oil filter adaptor plate and an oil temp gauge. What kinds of readings are you guys getting?
sddesigns
New Jersey Chapter
Apr 14, 2010 01:55 PM
sddesigns
New Jersey Chapter
Mar 24, 2010 11:43 AM
sddesigns
New Jersey Chapter
Mar 15, 2010 02:29 PM
sddesigns
New Jersey Chapter
Jan 28, 2010 05:46 PM
