i am nearing the end of the engine drop in y 96 it has a 4.9 in it i can not find the plug that goes in the alternator can any body provide me with description or pictures of were this wire is on the wiring harness?
mine was slightly different only one plug and then a wire that goes to the batt. is there any way u can tract the wires on the plugs and let me know were they go?
good possibility i pulled this thing apart nearly 2 years ago glad to finaly start getting it back together. also another questioon when i turn the ignition all im hearing is a clunk. im thinking starter. any other ideas? and if it is a start will one from a 91 work it looks a lot bigger.
A small green wire at one end of a three pin grey plug.
...The other wires in the plug...
White & black from the center, ->to a single grey connector
Yellow at other end -> to a ring terminal.
The output/charge cable is separate, and stand alone.
i actualy foud the wire it was behind the seat for some odd reason. i am using the batt from the black truck shows good charge every thing turns on but no turn just a clunk sound.
ok nother question pulled the starter and took a look at it it has the little spade fitting for a trigger wire but there is not one on the truck were can i connect this wire in at?
