300 I6 Low end Knock
Old Sep 7, 2009 | 04:00 PM
8525ford's Avatar
8525ford
Question 300 I6 Low end Knock
recently swapped out the eec iv igniton for the duraspark 2. Swapped out the manifolds for a clifford performance, and hooker long tubes, and have a holley 4 barrel to top it off. The truck starts and runs ok. The timing is about 10 degrees advanced. Problem is when i just crack open the throttle i get a loud knocking noise, and then as i rev it up it fades out. Could the carb be in need of adj. timing to advanced?? i put 93 octane in it and it didnt go away. need some things to try.
also when i take it out and drive it, if i really stomp on it
the truck falls flat on its face and bogs down bad?? thanks
Old Sep 7, 2009 | 04:45 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Some 300's were timed at 6 degrees depending on calibration.
Try adjusting the timing.
Also your timing curve on the vacuum advance could be way off.
Old Sep 7, 2009 | 06:26 PM
8525ford's Avatar
8525ford
i tried all kinds of timing adj. still there???
Old Sep 7, 2009 | 07:06 PM
bashby's Avatar
bashby
kill cylinders one at a time by pulling plug wires to see if the noise changes
