Axel Ratio?
Old Sep 7, 2009 | 12:15 PM
mhays2's Avatar
mhays2
Axel Ratio?
How does one determine what axel ratio the rear differential is (assuming it is as it came from the factory)?
Old Sep 7, 2009 | 03:37 PM
ljutic ss's Avatar
ljutic ss
There is an Axel code on the driver side door jamb, do a search under axel codes and you will see what ratio you have.
Old Sep 7, 2009 | 03:51 PM
06silvercrew's Avatar
06silvercrew
What he said, or easiest way is to just crawl under and look at the tag on the cover, it will say the ratio. If it has an "L" after it it means its locking.
Old Sep 7, 2009 | 04:15 PM
ptr34's Avatar
ptr34
most are 3.73
Old Sep 7, 2009 | 04:23 PM
mhays2's Avatar
mhays2
Mine was a "D1" (on the door-jamb) which is a 3.73 LS.
Thanks all, for your help.
Old Sep 7, 2009 | 04:58 PM
06silvercrew
Yeah im not sure about the earlier trucks, but I know ones like mine only were available with 3.73
Old Sep 9, 2009 | 08:42 AM
HeavyAssault's Avatar
HeavyAssault
Most PSD trucks will be 3.73 the gassers came with 4.10. DRW trucks can get the 4.30 with the Tow Boss packages.
Carlotta68
1997 - 2003 F150
Apr 19, 2014 06:41 AM
Oldhobbitfoot
Apr 20, 2012 05:20 AM
NotMyHusbandsF150
2009 - 2014 F150
Jul 5, 2011 07:40 PM
njeske
1983 - 2012 Ranger & B-Series
May 6, 2007 03:57 PM
ronchier1
1997 - 2003 F150
Jun 19, 2005 08:21 PM
