Sponsored by: Real Truck
3.55's Only...WTF??
Old Sep 7, 2009 | 10:25 AM
galaxyfe's Avatar
galaxyfe
3.55's Only...WTF??
So I'm on the Ford site building my '10 F250, and with a diesel, the thing will not let you select anything but a 3.55 gear. Even 3.73 it tells you to switch to V-10... What's up with that??
Old Sep 7, 2009 | 11:14 AM
senix's Avatar
senix
I tried myself. Not sure what the issue is, very strange. You can always go to the dealer if you want to spec one out.
Old Sep 7, 2009 | 02:57 PM
Tom's Avatar
Tom
I think it likely has something to do with people complaining about MPGs.
Remember, down in the 6.4 forum we normally get someone complaining about MPGs every week! How many complain that the 6.4 can't tow their trailer? Never seen one myself. Heck, even with 9,000 lbs behind me the tranny stays in overdrive and never has to downshift.
I believe 3.31 is standard now and 3.55 is the option in the F250s. Almost certainly to make the truck drink less while loaded. Also, the F250 is less likely to be dragging 15,000 lbs, and is more the type of truck people expect to tow occasionally and get reasonable fuel economy unloaded.
Makes sense to me, although I still wouldn't want less than my 3.73s.
Old Sep 7, 2009 | 07:08 PM
powerstroke72's Avatar
powerstroke72
According to the 2010 Order Guide, you can only get the 3.31 or 3.55 on an F-250 or 350 SRW truck with the diesel like Tom said above. You have to step up to the F-350 DRW to get the 3.73 in the diesel. They even changed the Tow Boss package this year. It used to have the 4.30 gears and now has the 4.10s.
Old Sep 7, 2009 | 07:39 PM
ruschejj's Avatar
ruschejj
I tend to agree on this, kinda bites. But, maybe with the 6 speed trans. it won't be too much different than a 3.73 with the 5 speed?
It's an expensive experiment but we'll have to wait for somebody to tell us what it drives like. More power, 6 speeds, 3.55 might work out ok.
Maybe we'll get lucky and have a way to lock out OD when we need the HP going down the road.
Old Sep 7, 2009 | 07:41 PM
tex25025's Avatar
tex25025
That takes me out of the ordering game for awhile. I won't go back to 4.10s. There is a huge difference between 4.10s and 4.30s while you are towing it is unbelievable.
Old Sep 7, 2009 | 07:57 PM
Tom's Avatar
Tom
The 2010 has the same engine and tranny we do in our trucks.
Old Sep 8, 2009 | 05:11 AM
senix's Avatar
senix
I think everything is the same till Jan 2010 when the new emissions come into play. Then that will be the big switch.
Old Sep 8, 2009 | 01:32 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Thread cleaned. Keep it on topic.
Old Sep 10, 2009 | 10:17 AM
galaxyfe's Avatar
galaxyfe
Plus now, if you plan on a lift with bigger tires, gears are going to be a necessity IMO. I know I don't want a 35"+ tire with 3.55's.
Old Sep 10, 2009 | 10:20 AM
tex25025's Avatar
tex25025
I never could understand any of that anyway. Too many negatives(in my opinion) and this is just another one here.
Old Apr 23, 2010 | 02:12 AM
big_saxy's Avatar
big_saxy
I was a little uneasy abou this topic as well. In january I traded in my wifes toyota camery for an 09 F-250 6.4 4x4 SC. Good riddance to that bucket! I expressed my concern to the salesman regarding the 3.55LS dana 60 rear end it listed. Im used to the lower the gears the better but he pretty much said the same thing, if i want lower gears i have to buy a gasser. They made me such a killer deal i couldnt let the truck go. I towed a friends chevelle from his place in vegas down to san diego to be restored. I figure I had a total of 7k behind my truck. I made it to San diego burning 23 gallons (350ish miles away) cruising 65mph. It was cake! i averaged about 16mpg on the trip. i was very impressed. I am confident it could handle much more with the same ease.
Old Apr 23, 2010 | 04:45 AM
smlford's Avatar
smlford
I think the gearing on the new 6 speed tranny will help alot plus give you the improved mileage when not towing.
The videos ford has put out about the towing ability of the new SD shows it's not lacking in the grunt department that's for sure!
Old Apr 23, 2010 | 07:23 AM
Tom's Avatar
Tom
16 MPG?!?
WOW! I can get that unloaded at 65-70 MPH, but with any kind of trailer I'm down in the 12-13s at best. 10 or less with an enclosed trailer!
I agree with you, though. These trucks are really amazing! I just drug 11,000 lbs 750 miles in my enclosed trailer and the truck hardly ever even had to downshift to pull hills. Many hills that my last truck, which was an '07 5.4L F150, would have needed to be in 2nd gear to pull were easily conquered in overdrive.
I love my truck. I do NOT love the fuel economy!
Old Apr 24, 2010 | 01:50 AM
big_saxy's Avatar
big_saxy
what size tires do you run?
