LED stop/tail lights
Old Sep 7, 2009 | 09:04 AM
MAXSD250's Avatar
MAXSD250
I installed a set of Retro-Solution LED Brake/tail bulbs in my '05 SD. They blink at twice the speed of sound! Any ideas?
Old Sep 7, 2009 | 11:00 AM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
In the installation instructions they SHOULD have told you what to do about that.....LEDS take way less current than standard lamps so usually you have to install a current limiting resister in series with the power line to lights. Usually (with a reputable supplier), the circuit for this is already installed in the new lamp fixture.
Old Sep 7, 2009 | 03:55 PM
MAXSD250's Avatar
MAXSD250
There were no installation instructions. They're just a plug in bulb.
Old Sep 7, 2009 | 05:05 PM
GregsSD's Avatar
GregsSD
Just go down to your local parts store and get an "Electronic" flasher to replace your stock flasher. Then they will flash at normal speed.
I believe it uses an EP-27 Electronic flasher.
Old Sep 10, 2009 | 04:47 PM
3800rs's Avatar
3800rs
got any pics of the lights out of curiousity ?
