84' E150 Van no spark
Old Sep 6, 2009 | 05:16 PM
ukuleleplaya's Avatar
ukuleleplaya
I was driving to work 2 miles from home (cold engine) and it just died. battery was dead after trying to turn it over twice but i think that is a old battery problem. I believe i have the TFI system due to the E core ignition coil. i was told to check the ignition module but on this system i don't think i have one. i also read about the TFI on the distributor but i was early morning and close to home so i couldn't have gotten too hot. Please help before i start replacing everything before i figure this out.
Old Sep 6, 2009 | 08:16 PM
ukuleleplaya
a little more 411. 6 cyl. 4.9L, 125K miles. i checked the obvious stuff wires, plugs, cap and rotor.
Old Sep 7, 2009 | 12:20 AM
TheKirbyMan's Avatar
TheKirbyMan
Are all wiring connections secure and in place? Like at the distributor, coil, etc.?
Old Sep 9, 2009 | 06:36 PM
ukuleleplaya
It was the TFI ignition module. Mounted at the base of the distributor with 2 7/32 bolts, thermal grease is mandatory or warranty is void. $40 @ Kragens and now I am back on the road.
Old Sep 10, 2009 | 02:23 AM
TheKirbyMan
Great, I'm glad you fixed it. Same sort of thing happens with the older Duraspark boxes too.
