Sponsored by: Real Truck
trailor lights not working????
Old Sep 6, 2009 | 04:57 PM
08 tuck man's Avatar
08 tuck man
I have an 08 F-250 superduty 4 x 4 crew cab. None of the lights work on any of the trailors I pull. The truck does recognize a trailor plugged up...
Any Ideas??
Old Sep 6, 2009 | 06:18 PM
bpounds's Avatar
bpounds
Do the brakes work?
Old Sep 6, 2009 | 08:26 PM
senix's Avatar
senix
if the brakes don't work then I would be checking your grounds.
Old Sep 6, 2009 | 08:30 PM
jonsk's Avatar
jonsk
Im having the smae problem, but my brake controller lights up. If i run a ground wire from my truck frame to my trailer frame then i get lights. Otherwise there not working. Im at the point of bringing it to a pro.
Old Sep 6, 2009 | 08:32 PM
senix's Avatar
senix
sounds like the wiring in the plug on your truck is having an issue to me. have you check the contacts on both the truck and the trailer?
Old Sep 6, 2009 | 10:06 PM
sdetweil's Avatar
sdetweil
but you have the solution..
where ever the ground lead is on trailer or truck is bad.
truck frame ground to connector, from connector to trailer frame
Sam
Old Sep 7, 2009 | 09:47 AM
08 tuck man
The brakes work. I've ran a good ground also.
I wonder what the fuses control the lights?
Old Sep 7, 2009 | 10:12 AM
bpounds's Avatar
bpounds
I hope that means the brakes actually work, and not just the illumination of the controller. Anyway, you have eliminated the ground as the problem, and that was the point of my question.
The fuses and relays for the trailer can be found in your owners manual. If you don't have one, download it here:
https://www.fleet.ford.com/maintenan...ls/default.asp
It seems unlikely that all the fuses for lights would fail at once, but it is possible if there is damage to the harness or even if too much water intruded into the connector.
I see these fuses in your manual:
#42
#44
#63
and relays:
#56
All of those will be found in the power distribution box under the hood.
Old Sep 7, 2009 | 10:29 AM
sdetweil's Avatar
sdetweil
On my F150 there were both individual circuit fuses and a master fuse..
when I put the license plate on the used trailer, it pinched the wires, and poof, blew the master fuse.. course it is in the footwell, and its SO easy to crawl on the floor from outside to look at the fusebox.. uck.. NO customer usage understanding..
just like the panel in the engine bay.. the drawings are one way, but the unit is 180 degrees turned..
Sam
rwlacks
Apr 9, 2015 08:51 AM
nunboutmuch
Electrical Systems/Wiring
Jul 24, 2009 11:31 PM
Bruteskeg
Sep 18, 2008 12:59 PM
gtmustang00
All Things Towing
22
Apr 19, 2008 10:58 PM
94Explorer
Jun 24, 2004 08:57 PM
