Idling Issues
Old Sep 5, 2009 | 10:14 PM
2005REDFX4's Avatar
2005REDFX4
Idling Issues
Hey everyone. I have an 05 with the 5.4. When I bought it used with 43k miles it had a little 'shimmy' to it when idling. It appeared to me to be more than the average idle. So I had them 'fix' it before I took possession. It seems to me that now I have to tap the gas harder than is necessary and it seems to lurch forward, not like it should. It also seems to shift awkward. I had an 01 and it didn't act this way. I know they're different bodies and such but it seems like it isn't running right. I just want some ideas on what the problem might be, if any. That way when i take it back with my extended warranty, I will have an idea of what to tell them to look for. Thanks a ton. You guys are extremely helpful to non-mechanics as myself.
Old Sep 6, 2009 | 01:22 AM
FTE Trigger's Avatar
FTE Trigger
Hhnmmm....
E-brake sticking?
Has your "shimmy" or idle issue felt like it has come back?
Or is this issue popping up just when the truck is in motion?
Old Sep 6, 2009 | 12:38 PM
2005REDFX4's Avatar
2005REDFX4
The 'shimmy' does appears to be coming back to a certain degree. Not as bad as it was before purchasing but definately coming back. I forgot to add that it 'shimmies' worse when its in drive but sitting still. Maybe it's nothing, just doesn't seem right.
johnfl
General Automotive Discussion
Nov 5, 2023 09:39 PM
bbshriver
Dec 23, 2011 08:52 AM
buckweet1980
Jan 15, 2011 09:43 PM
Scott99Z
Feb 7, 2004 02:39 PM
pensar
1978 - 1996 Big Bronco
Feb 6, 2000 07:01 PM
