Transfercase bolt head missing again!!
Old Sep 5, 2009 | 01:57 PM
erebus's Avatar
erebus
A few weeks back I noticed a leak in between the transfercase and trans, upon inspection two bolt heads were missing and three were loose. I ordered a new set of bolts and a new gasket. I also found that one u-joint was frozen, the one at the diff.
I removed and replaced the u-joint, installed a new gasket and the bolts. This cured the leak and a vibration that I was feeling in the drivers seat. Today I am changing the oil and noticed that it was leaking again and found one bolt head missing, the rest are tight and intact. The truck does have a vibration and I am unable to find it. What could cause the bolt heads to break off?
2001 f350 7.3 4x4 reg cab, no lift and stock tires.
Thank for your help.
John
Old Sep 5, 2009 | 02:03 PM
Kwikkordead's Avatar
Kwikkordead
That vibration you are chasing will definately break bolts.
Get the ride smooth again, even if it means having a whole new driveline built for your truck.
Stick or automatic?
Old Sep 5, 2009 | 02:10 PM
erebus's Avatar
erebus
Auto with 190,000 miles bought with 116,000. I am not sure if the trans is original.
Old Sep 5, 2009 | 02:14 PM
erebus's Avatar
erebus
The vibration that I have comes on at 50-55 mph and will stop if I let off the throttle. It will smooth out at 60 mph. It feel as if it is coming from the drivers side, but not the front end. Torque converter??
Old Sep 5, 2009 | 02:55 PM
farmdad's Avatar
farmdad
Did you check to see if any splined couplings had sideways play due to wear? That could give you a vibration.
Old Sep 5, 2009 | 03:07 PM
erebus's Avatar
erebus
If you mean the slip joint in the rear drive shaft, it is solid no movement and no klunk.
Also the rear diff does not leak at the u-joint.
Old Sep 5, 2009 | 04:25 PM
Kwikkordead
You can pin it down to driveline vs torque converter by shifting out of OD.
If the frequency of vibration remains the same, then it's driveline.
If it changes with engine rpm, then it's something forward of the tranny.
Old Sep 5, 2009 | 04:39 PM
erebus's Avatar
erebus
Kwik, I do not get the vibration with the od off. ( just ran out and ran the truck) Also noticed the weight on the drive shaft is rusted and does not look like a button as the front shaft weight.
Old Sep 6, 2009 | 07:42 AM
erebus's Avatar
erebus
Update: I placed the truck on stands and ran it through the gears. The vibration is coming from the trans and only in overdrive. Dropped the trans pan and found metal shavings on the magnet. The shavings ranged from very small up to shavings that you would get when drilling something. Looks as if I need a tranny.
Old Sep 6, 2009 | 09:26 AM
farmdad's Avatar
farmdad
Sorry to hear about the findings in the pan. Sounds like you have it diagnosed. Are you going to go with heavy duty (BTS or JW) or a good rebuild?
Old Sep 6, 2009 | 10:25 AM
erebus's Avatar
erebus
Finances will dictate if I will rebuild myself (with help) or see what price my brother in law can get on a ford reman. I am leaning towards the reman, my local dealer wants $2100. Hope the BIL can get it at cost + 10% ??????
Until then my morning coffee will be shaken not stirred.
Old Sep 6, 2009 | 10:45 AM
Kwikkordead
Well, at least you know what the problem is now.
BigBlue99
Aug 22, 2013 10:19 AM
riverrat41
Jul 29, 2010 12:36 PM
Brian460
Dec 18, 2009 11:39 PM
fairlaniac
1983 - 2012 Ranger & B-Series
Jan 31, 2008 09:57 PM
