Sponsored by: Innova
Quick ?
Old Sep 5, 2009 | 10:38 AM
V10Monster's Avatar
V10Monster
Quick ?
Sizes of the component speakers in a 2000 F250 ext cab. Thanks
Old Sep 5, 2009 | 05:49 PM
ReAX's Avatar
ReAX
It's that 5x7 odd size. They aren't components though, it's going to be a full range co-axial type. I think you can fit the 5 1/4" components in the stock hole without modification, but the 6 1/2" or 6 3/4" components systems will take a little trimming.
Old Sep 9, 2009 | 12:56 PM
V10Monster's Avatar
V10Monster
so which are which? Sizes for front and back. I'm gonna be orderin them online
Old Sep 9, 2009 | 02:15 PM
glruff's Avatar
glruff
FTE Leadership Emeritus
Where are you ordering from?
Crutchfield shows 5x7 for front and back. You probable should stay with the same size all away around and modify the mounting space to accomodate the size you get.
Old Sep 10, 2009 | 04:12 PM
ReAX's Avatar
ReAX
The bigger the woofer in the speaker, the clearer the low freqs will be (more or less). Myself, I would put 6.5" components in the front and spend a couple hundred dollars on them. Then the 5x7 mid grade speakers for the rear. The idea being you want the front stage to be very clear and concise, the rear channels are mostly filler so you can spend a little less on them.
