transmission trouble!!!!!
Old Sep 4, 2009 | 08:53 PM
that matt guy 12's Avatar
that matt guy 12
Hi, i am having problems with my truck. It is an 1994 f-150 2 wheel drive straight 6, standard transmission. I recently loss the abilty to switch gears, so i dropped the tranny out and replaced the slave cylinder which was leaking. Then i replaced the tranny bleed the lines and still i cannot engage the truck into gear. It switches fine as long as the truck is not running!! Anyone have an idea what the problem might be???????
Old Sep 4, 2009 | 10:31 PM
FTE Trigger's Avatar
FTE Trigger
Thread moved- from the '09+ F150 forum to the 1987 - 1996 F150 And Larger F-Series Trucks forum.
