No Bilstein Steering Damper?
Old Sep 4, 2009 | 05:03 PM
mechelement's Avatar
mechelement
I want to get those yellow and blue Bilsteins for the truck and they don't even make a friggin' steering damper.
What do you run for a steering damper? Should a truck this size have a dual damper setup?
FWIW, this place: http://www.shockwarehouse.com/index.cfm has a 25% off deal on those Bilsteins until the 30th of this month.
Old Sep 4, 2009 | 06:32 PM
12pump's Avatar
12pump
This isn't the yellow and blue, but it might help. Someone else did the research I'm just re posting it. Blistein 5100 Steering stabilizer # F4-BE5-A463-H6
Old Sep 4, 2009 | 07:52 PM
maevans's Avatar
maevans
Jason
These are the shock dimensions you can use to find a 4600 (blue & yellow) steering stabilizer
Travel length of 9 1/4"
Extended length of 24 3/8"
Collapsed length of 15 1/8"
I got the measurement off a stock stabilizer. I used these dimensions to find my 5100 stabilizer.
I'm trying to find the Bilstein chart with all of there shock Dims. when I find it again, I will post it or send it to you in a PM.
Old Sep 18, 2009 | 09:55 PM
mechelement
I went onto Bilsteins website and looked for a chart like you mentioned, but couldn't find one. They only have application charts w/o any dimensions. Did you happen to find that chart? I finally installed the shocks.
