Shuddering at 65 mph
Old Oct 30, 2002 | 10:52 AM
janjaz's Avatar
janjaz
Hi All,
My Exp 97 XLT with 60,000 miles is shuddering around 65 mph and up. Doesn't do it at low speeds. The vibrating can be felt all over. I will be taking it into the shop soon. Tires have about 12,000 miles on them. Since I don't know much about trucks, are there any checks or things to note while driving it to help the shop figure out what it is? Hoping to save some time and money. Thanks.
Jan
Old Oct 30, 2002 | 11:11 AM
rwarrencfp's Avatar
rwarrencfp
Does it only do it at 65? I had a shuddering or vibration that felt like I was going over a washboard road. It did it at various speeods though. It turned out to be the tranny fluid. A flush and re-fill stopped the problem.:-)
Old Oct 30, 2002 | 10:19 PM
buzzard's Avatar
buzzard
>Hi All,
>Jan
More times than not, vibrations at certain speeds are caused by improperly balanced wheels (tires). Have you balanced or rotated the wheels since you got the new tires 12,000 miles ago? If not, you may have reduced the lives of the tires quite a bit especially if you haven't kept the correct air pressure the whole time??? Head back to the tire shop and have them balance and rotate. This should take care of your problem.
Old Oct 31, 2002 | 11:27 AM
janjaz's Avatar
janjaz
[updated:LAST EDITED ON 31-Oct-02 AT 12:34 PM (EST)]Yes, it does seem like I am driving on a washboard but only over 65. Will check into the changing of the tranny fluid and balancing the tires. Thanks for the advice. I will let you all know what works. Thanks again.
Old Oct 31, 2002 | 12:35 PM
Animo1's Avatar
Animo1
I had similar problem on my 99 with 60,000 miles and turned out to be a warped front rotor. I replaced it and did brakes both fronts and she rides like new again.
Old Nov 19, 2002 | 04:05 PM
janjaz's Avatar
janjaz
Hi All,
Want to update you all. I had my Ford dealership do the 60k maintenance on my expy which included maintenance on the transfer case. I also had them change the transmission fluid which they said was dirty and balance & rotate tires. The guy said that one tire was really out of balance and showed me how to tell that they had been balanced. There is a weight on the outside of the rim that you could tell had been moved. The truck drives a lot better than before especially over 65. Thanks for everyone input on this topic. This is truly a great site with a wealth of info! Thanks!
Jan
Old Nov 19, 2002 | 07:52 PM
the4by4freek's Avatar
the4by4freek
