hazzard lights
Old Sep 3, 2009 | 08:27 PM
joe f350's Avatar
joe f350
hazzard lights
i need to get mine working and they dont work at all
Old Sep 3, 2009 | 08:47 PM
johnboggs21's Avatar
johnboggs21
hows the switch?
Old Sep 3, 2009 | 09:00 PM
joe f350's Avatar
joe f350
it pulls out smooth but it dosent make a sound
Old Sep 3, 2009 | 09:13 PM
dyoungen's Avatar
dyoungen
You talking about the switch in the steering colum?
Old Sep 3, 2009 | 09:15 PM
joe f350's Avatar
joe f350
yep i need the to be leagl in cali
Old Sep 3, 2009 | 11:04 PM
banks7.3's Avatar
banks7.3
check the flasher relay
check the flasher relay, should be located on the fuse block. there should be two relays, one for the flashers and one for the turn signals. flasher relay could possibly on the back side of the fuse block. i haven't checked on my truck yet.
also check your fuse.
Old Sep 3, 2009 | 11:51 PM
joe f350's Avatar
joe f350
what fuse is it
Old Sep 4, 2009 | 08:10 AM
rupejosh's Avatar
rupejosh
check all of them
Old Sep 4, 2009 | 09:38 AM
banks7.3's Avatar
banks7.3
check the panel that you pull off the dash from under the steering column, the fuse function and location should be listed with a diagram.
Old Sep 4, 2009 | 05:26 PM
lmnr0026's Avatar
lmnr0026
My switch is going bad. Sometimes the hazards don't come on until I wiggle the switch a little. It pulls and pushes to the column smooth, but there is a problem with the connection somehow. If your fuses are good, might be the switch.
