Fuel leak
Old Sep 3, 2009 | 04:28 PM
mysocks4's Avatar
mysocks4
Fuel leak
Hello All. I am brand new to the diesel scene, bought my first diesel a month ago. I have a 1997 F250 HD 4X4 with the 7.3 TD. I love this truck, it is awesome! Long story short, I discovered a fuel leak coming from what looks like a diaphragm underneath the turbo at the rear of the motor. I searched the threads and found plenty of info on the lift pump, fuel lines, blue hoses, ect.; but nothing about this part. Can anyone shed some light on this or point me in the right direction? Thanks - Gary
Old Sep 3, 2009 | 04:45 PM
JAFO1's Avatar
JAFO1
Welcome! You probably are talking about the lift/fuel pump. Common leaker. As you can see, lots of good info here. Lots of good threads about fuel pump changes. I forget the size off hand, someone will chime in, but you will need a large wrench bent to get the banjo bolt off the back of the pump off. Any shop that works on 7.3 PSD's will have one and will probably help you bend the wrench. I got mine at the local pawn shop, maybe $5.
Good luck. Ask questions.
Old Sep 3, 2009 | 04:52 PM
mysocks4's Avatar
mysocks4
Thanks for the info JAFO1. After doing more searching on here, I did find a link that is similar to my problem - https://www.ford-trucks.com/forums/5...r-housing.html Apparently, I should have mentioned that my truck is a California truck. Had I known that, I would not have bought it. Damn liberals screw everything up!
Old Sep 3, 2009 | 05:10 PM
JAFO1's Avatar
JAFO1
Glad you found what you are looking for! I know very little about my truck and less about the Cali's.
Old Sep 3, 2009 | 07:15 PM
Cuda_jim's Avatar
Cuda_jim
You may be able to un-screw the pulse damper on top of the FP, it's worth a try since the turbo needs to come off for a Cali fuel pump replacement.
Old Sep 3, 2009 | 07:30 PM
hi mile ford's Avatar
hi mile ford
believe its a 32 or 34 mm for the back bolt cant recall exactly while you have it off replace the blue fuel lines as well you will be glad you did you will probably have to work the pump around a bit to get it out.
Old Sep 3, 2009 | 08:14 PM
mysocks4's Avatar
mysocks4
Is the pulse dampener the round diaphragm looking deal just below the turbo? So the fuel pump is under the turbo...is the diphragm part of the fuel pump? Does this mean I need to replace the fuel pump? Thanks all for the insight, especially about replacing the blue lines.
Old Sep 3, 2009 | 08:35 PM
hi mile ford
the fuel pump has a weep hole in it after so long the hole wears and leaks then one day the top of your intake will be full of fuel and will be leaking down the back of your motor. the fuel pump swap out only took me less then two hours and the pump was around a hundred or a hundred fifty.
Old Sep 3, 2009 | 10:54 PM
mysocks4's Avatar
mysocks4
Got it. I have been reading posts for hours about fuel leaks on this site. There is such a wealth of knowledge on here. Thanks for all the info. I definetly have a project this weekend. I am also replacing the glow plugs/wiring/valve cover gaskets/glow plug relay this weekend with a kit from Accurate Diesel I purchased on Ebay. I'll post how it all goes...
Old Sep 4, 2009 | 01:03 AM
pjwoolw's Avatar
pjwoolw
It might have vibrated loose. They screw on. See if you can tighten it. When the engine has cooled a bit.
The Cali trucks makes more power than the 49 staters! At least when new.
Old Sep 4, 2009 | 11:23 AM
mysocks4's Avatar
mysocks4
Thanks PJ, I'll give that a shot first!
Old Sep 4, 2009 | 12:08 PM
97-7.3's Avatar
97-7.3
I copied and pasted this from an earlier posting .... used it to change my fuel pump.
Sparke
Here's a writeup that will help with changing the pump:
FUEL PUMP REPLACEMENT by Sam Miller
I recommend disconnecting batteries. There is no way to work around the glow plug relay without touching it. Then set up a parts tray, run a good light, throw a pad over the radiator and go for it.
Also, if you have a HPX crossover hose installed, it is easier if you disconnect it from the passenger side oil rail and tie it out of the way. Remove “Y” pipe (compressor manifold) from turbo, taking care not to lose the rubber O-ring inside the fitting (Marmon clamp). If you loosen only the lower clamps on the two silicone hoses the whole assembly can be removed easily and set aside. Cover the openings with rags or plastic wrap and secure with rubber bands.
Draining the fuel filter/water separator canister. You will want to either place a container under the vehicle to catch the diesel (a hose pushed on to the drain tube sure prevents a mess), or pump the canister dry once you get the filter out, in which case you won’t slide the yellow lever to “DRAIN.” This is a good occasion to inspect and clean the interior of the canister, so removal of the filter and heater is advised. (Remember, the plastic heater standpipe is LEFT HAND THREADS.) A 7/8” crow’s foot wrench works best, but I have loosened it with a regular open-end wrench. Pull off the heater wire connector with needle-nose pliers. Now you can clean the canister and check for cracks or leaks. You’ll be amazed at the crud in there.
Disconnecting hoses. There are two hoses connected to the top of the pump and one at the bottom. The two top hoses are protected by a removable clip-on heat shield (just yank it off). You can only get to the clamp on the pump side of that bottom hose. And finally, the water drain hose at the front passenger side of the filter housing.
Remove the two bolts attaching the fuel pressure regulator with 10mm and carefully pry it back from the filter housing, taking care not to lose the O-ring. Good time to clean the screen and examine condition of O-ring. There is also a short section of 5/16” hose that may need to be replaced.
Separate the wire harness connector on the passenger side of canister and remove positioning clamp with 8mm. It will NOT slide off the tongue of the clamp as you think it might, since the tongue is barbed. (Remind you of anyone?)
Disconnect wires connected to the canister, two on drivers side, one at bottom rear. (So now you want to know what they are? Aw geez, you’re one of THOSE guys: Oh, all right: On the driver’s side, the top connector on the side of the Water Filter/Water Separator Assembly is the fuel heater connection; the connector directly beneath it links to the Water Sensor; and the connector on the bottom rear of the Assembly is for the filter restriction sensor. I believe it is a vacuum switch. Note: In 1996 the fuel filter restriction sensor was moved to the fuel pressure regulator, driver’s side of filter housing. Happy now?)
To continue: Two bolts holding down the filter canister are 13mm. You can lift the whole filter assembly up and forward out of the way with the long blue hose still connected at the bottom.
Getting the pump out is not difficult, using a 1 1/4 inch box end wrench, heated and bent to clear the turbo pedestal, while removing the large banjo bolt. You just have to be patient and content with getting only small incremental turns on it. It takes a while. The two metal ring-gaskets will sometimes remain stuck to the banjo fitting. You can remove them once the pump is out of the way. You do not have to remove or loosen the fuel supply tubes connected to the banjo fitting.
At this point, I advise examining your new pump to see how the tappet connects. This will help you visualize how careful you must be so you don’t lose the tappet in the process of removing the pump. It is not necessarily fatal if that happens, but it is very disconcerting to lose the tappet into the bowels of the engine. If you can’t retrieve it, then it will probably wind up in the oil pan.
Now, remove the two 10 mm bolts holding down the pump and prepare to carefully remove the pump from the crankcase bore. Be careful here so as not to lose the tappet into the cam crankcase. If you want to assure that the tappet will not be lost, you can turn the engine over by hand until the cam lobe that contacts the tappet rotates to the top. It will actually push the pump upward if the retaining bolts are removed. With careful twisting and pulling you will eventually be able to lift the pump straight up and out of the engine. If the tappet comes with it, then I advise a high-five or fist-pump or maybe even a celebratory beverage.
Cover or stuff a rag into the pump hole and it's a good time to clean the entire valley. Kind of like being on a treasure hunt, you'll be amazed at what you find down there; valve caps, wire ends, wedding rings, cat hair, baseball gloves, wrenches... It's a lot of fun getting back all your tools.
Check out the exterior of the fuel filter canister. Clean the three wire terminals, check for leaks or cracks and clean everything so if a leak shows up later you'll know exactly where it originates.
Time to put things back together. Remove the two metal banjo gaskets if you haven't already. You might need a knife blade to get them loose. Be sure the interior of the banjo fitting is clean and free of debris.
Hoses: I got 3/8 inch 400 psi diesel-approved fuel hose from NAPA by the foot (by the inch, actually) and simply cut new hoses to match the old ones, three altogether on the pump and a 5/16 inch hose on the regulator. I installed them at this point, along with the clamps. I recommend tightening the clamps just enough so they are 'pre-positioned.' When the time comes to give them a final set it makes it easier not to have to chase them around with two hands. (One exception: the hose clamp on the bottom of the filter assembly must be tightened completely. You just can’t get to it once everything else is in place.)
If nothing fell into the hole or onto the cam then lower the new pump and tappet. I use a little anti-seize on the housing, thinking it might make removal next time a little easier. Grease should already be on the O ring, but if not, I'd grease it. Tighten the bolts carefully to secure the pump. Make sure the pump does not get in a bind. Just tighten the bolts evenly and it should go into the bore ok, regardless of where the cam eccentric is positioned.
The hardest part of the whole operation, for me at least, was getting the banjo bolt restarted. You will quickly come to understand why the shop manual calls for removal of the turbo pedestal for this operation. (Plus, more shop time equals more money. duh!) You will wish you had a Dremel tool and could cut away some of the 'webbing' between the legs of the pedestal. It’s a bit of a struggle, figuring out how to position your hands and fingers for the most efficient way to start that large bolt.
Slide one new metal gasket onto the bolt, insert it into the banjo housing and have the second gasket ready to slide into the slot on the interior side of the fitting as you push the bolt in. It may take a couple of attempts to get that second gasket onto the bolt. Just be sure it doesn’t slide on through the fitting and disappear on top of the manifold beneath. You might even apply a small amount of RTV or some handy ickumpucky on it so it doesn’t sneak away so easily. Now you just have to carefully turn the bolt with some pressure behind it to 'catch' the threads. Once it's started, then it is just a matter of wrenching it in, one tooth at a time. Here's where patience comes in again. It is a character-building exercise. Eventually you'll get it in. Snug it down, recheck the pump hold-down bolts for tightness and you're through the worst of it. Time for another congratulatory coffee break. Sometimes even an adult beverage is deservedly appropriate here…
Adjust all the hoses and be sure the clamps are on and positioned for easy access. (Once again, the lower hose will have to be clamped securely to the filter canister at this point since you won’t be able to reach it once the assembly is bolted down.) Lower the filter assembly back onto its pedestal, connecting the lower hose to the fuel pump as you go. Check that the wiring looms and connectors on both sides are positioned correctly. Adjust all three short hoses correctly and tighten the clamps. Remember to “aim” the clamps for easy access later, just in case there is a leak and you need to get to them with a screwdriver or ¼ inch socket. Don’t forget to reconnect the drain hose also. And CLOSE THE YELLOW WATER DRAIN LEVER.
Install the two 13mm bolts securing the filter housing (I use just a touch of anti-seize) and tighten. Plug in the three wire connectors to the canister and join the loom connectors on the passenger side. Reinstall the 8mm hold-down bracket. (or probably like most of us do, just wire-tie the connector to the GP loom).
Re-attach the FPR, being careful to install the O-ring. Tighten the two 10mm bolts evenly so the O-ring sets properly.
Reconnect HPX hose, the “Y” pipe (don’t forget the O-ring) and whatever else you might have removed or disconnected. It is a good time to also re-dry the manifold Valley of Death. Looking for leaks will be a lot easier if everything underneath starts out dry. A long screwdriver and some paper towels work great. Just be sure to get them all back out before you finish.
Check everything twice. Pry back up whatever wires and brackets and connectors and hoses you mashed down by lying on them. (If your A/C ever quits working, it is often the top electrical connector that has taken a beating from your body weight…) If it all looks good, reconnect the batteries and you are ready to start.
I leave the heat shield covering the two tops hoses off at this point, just so I can look for leaks after I fire it up. Don’t forget to eventually snap the shield back on, because there is a lot of heat back there and the hoses will definitely last longer.
A couple of notes here: If you shimmed the FPR, I would remove the shim at this point and start over with a stock set-up. Once you are up and running again, you can work the pressure back up towards the 70’s, using whatever shims work best.
A NOTE OF CAUTION: The FPR housing is very fragile. It is extremely easy to crack the housing by over tightening the Schrader valve or any fittings you might insert to accommodate a PSI gauge. BE VERY LIGHT ON THE TOUCH WHEN TIGHTENING ANYTHING INTO THE SCHRADER VALVE OPENING, especially tapered NPT fittings.
If everything is working ok, it should fire up within a few cranks. Thereafter, it takes a while to purge the air, usually a couple dozen miles of driving before things begin to settle back in to near normal.
WARNING: You will want to take a good light and look for leaks after the engine is running. BE CAREFUL. The fan and belt can change your nickname to Three-Fingered Jack in a heartbeat.
With any luck at all, you are dry as a bone and ready to roll. Check it again after your test-run.
Good luck,
Old Sep 4, 2009 | 12:26 PM
mysocks4's Avatar
mysocks4
Thanks a bunch... I printed this out and will be tackling the pump later this afternoon. Thank you all for the responses and help.
Old Sep 4, 2009 | 12:43 PM
Neal 97 250's Avatar
Neal 97 250
97-7.3 reps sent.Thanks for posting that in two threads! Way to go!
Old Sep 4, 2009 | 05:29 PM
Cuda_jim's Avatar
Cuda_jim
That's a great write up...for a 49 state (Fed) engine. He has a Cali model. A few things are different. The pulse damper is in the way and the banjo bolt is further rearward placing it under the turbo pedestal. It's a PITA but doable.
Once you get the damper out of the way the banjo bolt can be accessed with a 1 1/4 socket and an extension that fits. You will need to pack the socket so the banjo bolt just barely sticks out of the socket, then lightly tape it in place.
