hpop
Old Sep 2, 2009 | 11:04 PM
bryanlindborg600's Avatar
bryanlindborg600
hpop
i've looked in my book to find what and where this is, but i feel like a bit of an idiot not knowing what it is or where, i've read on other forums people have flushed them and it helps the motor run better? i also would like to do this but i need to know what it is?? thanks
Old Sep 2, 2009 | 11:18 PM
rideracelivemx7's Avatar
rideracelivemx7
its the first thing you see infront of the fuel filter housing, gold metal tank if you will, you cant miss it, your heater core line runs right infront of it, theres a little allen head bolt in it i belive and you pull that when you do an oil change and you can just suck out the old oil with a seringe of some sort and replace with fresh oil when completing the change
Old Sep 2, 2009 | 11:23 PM
bryanlindborg600
so do you fill back up through same hole you drain it out of? if so do you fill it to where it starts to leak back out or?
Old Sep 3, 2009 | 05:03 PM
MisterG's Avatar
MisterG
go to powerstrokehelp.com, he demonstrates how to do it in a short video.
