Rough riding
Old Sep 2, 2009 | 02:55 PM
cabloom300's Avatar
cabloom300
Rough riding
I put new front shocks in about a month ago and it helped my ride a little but still no where where i thought my ride quality should be. Do the coil springs wear out and need replaced to? is it just being a older truck why it rides this way?
PS truck is a 95 f150
Old Sep 2, 2009 | 05:36 PM
Neptoess's Avatar
Neptoess
it won't ride like a caddy, but worn out suspension bushings will make the ride a bit rougher. Sway bar bushing kits arent very expensive. I'd start there
Old Sep 2, 2009 | 05:42 PM
skaterbro's Avatar
skaterbro
Yes, your coil springs can wear and sag. They can also get bad enough to where they actually put more weight on the shock absorber and not allow it to dampen the way it was designed to.
Old Sep 2, 2009 | 10:08 PM
cabloom300's Avatar
cabloom300
so should i start with the new bushings? due to the fact theyd be alittle cheaper
Old Sep 3, 2009 | 01:19 PM
Neptoess's Avatar
Neptoess
that's what I would start with. your front end should noticeably sag down if your coil springs are bad, just like the rear will if the leafs are. you can push down on the front and if it keeps bouncing then your springs are likely bad. I just think it's alot more common to have worn out bushings than coils
