Severe Static on New CB with Engine Running
I recently installed a cobra CB radio in my 2005 F250 6.0. Power and ground are both coming from Cigarette lighter. Antenna ground is coming from negative battery terminal.
UPDATE: I did some reading and found out that running the wires directly to the battery may help. I wired the radio + straight to the battery and the ground is going to a ground point in the engine bay. No difference at all. Very loud static when vehicle is running.
Whenever the engine is running, I get lots of static. If I turn on the fans (a/c), it gets much worse. It also gets worse if I adjust the windows in any direction. (Like a whine with the window motor) Pretty much any electrical activity. When the engine is off/keys are out, it work perfect.
Also, I have a ground loop isolator from a previous project, but I couldn't figure out how to hook it up to the power. It's for audio cables so I wasn't sure how to do it. I'll include a pic that looks similar to my ground loop isolator.
I'm leaving town tomorrow and would love to have this solved! Thanks in advance!!
William
<a href="http://s66.photobucket.com/albums/h268/qwertmonkey/?action=view¤t=image020.jpg" target="_blank"><img src="http://i66.photobucket.com/albums/h268/qwertmonkey/image020.jpg" border="0" alt="Photobucket"></a>
I'm assuming I need this part because the ground loop insulator will not work? The only reason I ask is because I remember buying the insulator for the same problem, but for a dvd install on another car.
Also, I was at Walmart and didn't see it. Would best buy have it?
Thanks,
William
Thanks
Run both leads to the battery.
Ground the chassis of the radio.
If its a crappy antenna, go buy a good one.
If its a mag mount antenna no ground is needed.
If you drilled a hole in your roof no extra grounding is needed.
Anything else ground.
If its on the roof, move antenna towards the rear of the cab.
If there isnt one, add a fuse to the power wire.
If you are running bigger power use at least 8 gauge wire.
One problem with going to the battery is remembering to shut it off.
If you are running bigger power watch out for the internal cooling fans coming on if the inside of the truck gets hot and killing your battery, most internal cooling fans cant be shut off with the power switch.
Noise interference can be a compound of several different issues. One, the radio itself may have a ineffective or "cheap" built-in high pass line filter. second, the vehicle itself may have excessive noise created by it's own factors (worn or defective alternator and/or wiring as well as a inefficient battery amoung others).
Some key items: Provide a quality power lead of at least 10 or 12 awg (if a stock radio). Purchase the type that has the positive and negitive combined or you can twist the leads together using a drill which helps reduce any coupling effects or you can purchase a higher quality shielded power cable. Go direct to the battery as previously mentioned but try as short a route as possible without excess loops and trying not to cross over other electrical sources. Crossing 90 deg instead of parallel helps if unavoidable. Purchase a quality aftermarket high pass filter for the "power" line. (your audio filter is designed for a stereo system and wont work in a mono system. If it did work, chances are the noise would still be present on transmit). Ground the radio to the chassis with a large awg or braided cable as short as possible. Your alternator system may need to be addressed as well and there are filter systems for these as well. Put your stock am/fm radio on AM and compare the noise quality with that of your CB. It's a very good chance your CB could be the contributing factor. And last but not least (and you might try this first) is make sure the antenna is in good condition and is properly tuned to the radio. If the SWR (standing wave ratio) is high it can be a likely contributor. Most radio shops can do this or you can purchase one for yourself, a inexpensive one will do the job. Sorry for the long post.
If you ground the shield of a cable in more than one spot you get ground loops which opens up a whole 'nother can of worms.
I left the CB off (switched off) all day yesterday so I'm not sure what drained it. I didn't even drive the thing yesterday. What do you mean by internal cooling fans. Do you mean fans inside the CB?
Also, I've tried running both - and + to the battery. I have a fuse for the + lead. I haven't mounted the antenna yet so It's grounded to a ground in the engine bay. When I get my permanent antenna, (a 102 whip) it will be mounted behind the cab.
I will also try grounding the CB itself. I think that will help because changing the lead from the cigarette lighter to the battery made no difference. I think I may be getting the interference from the box itself.
Before you even mount a CB, Get a noise filter for CBs from Radio Shack or from a ham radio shop.
Run a red +12VDC cable from the battery (temporarily run it through the window). Run a - black the same path. Install a fuse at the battery end.
Test 1: Use the noise filter on the 12 V DC power for the CB just before the +12V DC connection to the CB. You can leave the fuse on the back of the CB that comes with most CBs Connect the red and black wires appropriately.
test 2: If you have noise, temporarily use the AM/FM in-dash 12 V DC power to determine if its the CB or the power. If using the am/fm radio power still has noise, connect the noise filter. If it still has noise, its a cheap CB radio and it will never work properly in that truck.
If there is no noise with test 1, run the wires properly from the battery to the CB.
If you are concerned about draining the battery, install an ignition switched relay or a I|O switch under the dash.
. I got another CB, and tried it, and turns out. It was the CB in the first place, not the truck LOL
