transmission swap question
Old Sep 1, 2009 | 01:57 PM
Bob1979's Avatar
Bob1979
Hey all, I have a 1979 Ford F100 w/302 I'm going to start restoring. The C-6 auto trans in it is a 3 speed. I would like to put a another transmission that has overdrive on it for the highway gear. As of now it whines pretty good at 75 mph and I hate to drive a long distance on that rpm for the motor and the gas. Does anyone know what is involved in putting an overdrive trans in? Like is it a module or just as simple as adding an O/D button? 1979 did not come with OD. I should add that there is a 9" rear with 325's in it and the speed odometer reads 65 mph when my GPS reads 55mph. I do like the power off the line but that extra gear in the trans would be nice. Your thoughts!!
Old Sep 1, 2009 | 02:20 PM
85e150's Avatar
85e150
AOD from '88-'93 will work. Can be beefed a bit, but these model years are the ones where the factory actually fixed some of the many flaws in this trans. Get one from a V8 or truck 6 or V8.
Links:
http://www.tciauto.com/Products/Ford/ford_aod.asp
http://ckperformance.com/ford_aod.html
http://www.transmissioncenter.net/AOD.htm
http://www.becontrols.com/products/aodcat.htm
The cost to swap in an OD will vary, depending on where you get the trans and if you get lucky in getting one. TCI has dimension info for trans, so you can measure yours and compare, see if you need DS or cross member work. The AOD requires a TV cable or linkage (or it burns up) so that and the shifter need to be changed/added/adapted.
For around $3000, you keep your C6 (not a C4 is it?) and bolt a Gear Vendors OD to the tail, and now you have a 6 speed.
http://www.gearvendors.com/
Additional "spotters" info:
https://www.ford-trucks.com/article/...ers_Guide.html
Write up on AOD job:
https://www.ford-trucks.com/article/...rd_Bronco.html
Last edited by 85e150; Sep 1, 2009 at 02:27 PM. Reason: Overwhelm OP with expensive options...
Old Sep 1, 2009 | 02:51 PM
andym's Avatar
andym
LOL
You need an overdrive trans. The AOD is the easiest route.
Old Sep 2, 2009 | 10:34 AM
Bob1979's Avatar
Bob1979
Good info
From a bolt on tail I can get 3 extra gears added for a total of 6 gears? I'll take a look at the links. For 3k that would be worth it. I'm going to be completely restoring the truck once I get all the part together. The LMC catalog is a great source for parts. I think I could use something from every page..lol.
Thx
Bob
Old Sep 2, 2009 | 12:15 PM
Kemicalburns's Avatar
Kemicalburns
you also have the option of a 5 speed manual tranny if you want to go that route.
M5od which is an ok manual or the stronger zf 5 speed. the zf has a granny low first which is very nice and of course has the od gear for the hwy. u didnt mention if your truck is 2wd or 4wd so be sure that the tranny you grab is specific to that to help with the install.
Old Sep 7, 2009 | 11:22 AM
Bob1979's Avatar
Bob1979
It is a 2 wheel drive. I'm very impressed with the Gear Vendors products. I had to read it through carefully to get the full understanding and even still some eludes me, but I get the meaning of what it does. Not cheep at $2600. but would probably pay itself off at some time. It seams like an easier way to got if I can put the cash together. Thank for all the help guys. I'll keep you updated and get a pic up when I get started.
Old Sep 19, 2009 | 10:30 PM
hcbph's Avatar
hcbph
OD Unit
Just saw this. If you're interested in more on the GV OD unit, check out Hot Rod Magazine, they're used it on a number of project vehicles in recent years. I think the last one was just a few months ago - a low buck high HP pickup. Seems to hold together well. I'm thinking of the same thing once I get my truck paid off.
Paul
Jon351m
Dec 15, 2011 05:02 AM
MLRTME1
17
May 23, 2010 08:27 PM
Polkster
Aug 12, 2008 07:34 AM
ronclark
1983 - 2012 Ranger & B-Series
May 2, 2006 09:39 PM
