F250 Camber Adjustment?
Camber/Caster
1996 f150 4x4 After reading reading and reading, I have positive camber at driver front and negative on passenger side i've come to the conclusion to check1st then replace all four ball joints and confirm camber angles not using camber shims. Truck will grab in rutts or rise's in the street and will manuever in various directions however all is tight up front new steering gear box that had about 3in play new shocks and coils. In previous if a tire has postive/neg. camber the tire is not flat to surface. Mine has positive on driver side neg on passenger witch will force positive pressure where tread has more contact and cause it to steer to the right, in other words both tires are tilted to the left it will steer right.
Joey Wooten
May 16, 2017 10:38 PM
dlash74
May 26, 2010 09:08 PM
